Mon premier build multi quad
Modérateurs : Dehas, David
othala
Re: Mon premier build multi quad
Message non lu par othala »
Apres une discussion avec Nabil on est partit sur un build legerement different, des hélice en 9 , une lypo 3S nano-tech ce qui donne ca :
Moteur x 4 = http://www.hobbyking.com/hobbyking/stor ... Motor.html" onclick="window.open(this.href);return false;
ESC x 4 : http://www.hobbyking.com/hobbyking/stor ... ware_.html" onclick="window.open(this.href);return false;
Lypo : http://www.hobbyking.com/hobbyking/stor ... _Pack.html" onclick="window.open(this.href);return false;
Adaptateur HXT - XT60 : http://www.hobbyking.com/hobbyking/stor ... earch=XT60" onclick="window.open(this.href);return false;
Helice noir / orange : http://www.hobbyking.com/hobbyking/stor ... _set_.html" onclick="window.open(this.href);return false; - http://www.hobbyking.com/hobbyking/stor ... 047%20228x" onclick="window.open(this.href);return false;
Connecteur XT60 Male : http://www.hobbyking.com/hobbyking/stor ... NUINE.html" onclick="window.open(this.href);return false;
Connecteur XT60 http://www.hobbyking.com/hobbyking/stor ... _bag_.html" onclick="window.open(this.href);return false;
Chargeur : http://www.hobbyking.com/hobbyking/stor ... Cells.html" onclick="window.open(this.href);return false;
APM : http://www.hobbyking.com/hobbyking/stor ... _BARO.html" onclick="window.open(this.href);return false;
GPS : http://www.hobbyking.com/hobbyking/stor ... odule.html" onclick="window.open(this.href);return false;
Low voltage Alarme : http://www.hobbyking.com/hobbyking/stor ... s_4s_.html" onclick="window.open(this.href);return false;
Telecomande : http://www.hobbyking.com/hobbyking/stor ... ware_.html" onclick="window.open(this.href);return false;
TX + RX http://www.hobbyking.com/hobbyking/stor ... II_RX.html" onclick="window.open(this.href);return false;
Pensez vous que tout y est je commande demain ! -y-
Blackout Hex- Naze32 - Sunnysky X2204
TBS pro - Naza Mv2 - T-motor 900kv
F450 - KK2 - D2830
Bixler 1
FT Guinea en cours de build
Ludo44
Message non lu par Ludo44 »
si je peux me permettre,
pour la radio, choisi plutot la 9XR: http://www.hobbyking.com/hobbyking/stor ... dule_.html
elle a deja le retro eclairage, plus de memoire, est equipe pour le flashage open TX ou autre, et les manches sur roulements,
choisi plutot un gps avec compas deporté pour l'APM, tu aura de bien meilleures performance et moins de soucis du au vibrations,
pour les moteurs, meme si ils ne sont sont pas mauvais, (j'en ai 6 sur un Y6), prefere plutot les sunnysky 2212 980 KV,
ils sont de nettement meilleure qualité (monté sur mon quadri), j'ai pu faire la comparaison et il n'y a pas photos,
enfin, pour les helices, choisi plutot des gemfan, elles sont plus rigides et le comportement en vol n'en sera que meilleur, sans parler de l'equilibrage qui a son importance (toujours les vibrations)
bonne reflexion et bon montage
loren3372
Message non lu par loren3372 »
bonjour
SUNNYSKY Angel A2212 2212-980KV
1-8S Lipo Battery Voltage Tester and Low Voltage Buzzer Alarm
pour info:
si tu commandes chez HobbyKing hors E.U pense a prendre le mode de livraison le moins rapide.
en mode express il y a plus de risques d'avoir des frais de douanes.
attention a la société de livraison SCS car elle demande a percevoir les frais de douanes pour débloquer la livraison de ton colis,parce que s'il y a taxe a percevoir cela se fera uniquement pas les douanes Françaises ou par la poste Française et non pas par une société de livraison étrangère.
bonne journée :merci:
othala
Merci à vous deux pour vos précieux conseils je vais passer en revu le tout et espérer commander dans la journée ! :-)
F450 - KK2 - D2830
Bixler 1
Message non lu par cubensia »
La 9x et le module que tu a choisi vont devoir s’accommoder d'un peu de bidouille
En effet il y a un plot plastique dans le slot de la 9x qu'il te faudra faire sauter ... ( on trouve des tutos sur le net )
Et pour la télémetrie en retour sur la 9x çà ne fonctionne pas en natif ( que l'on me corrige si je me trompe )
Il faut bidouiller un peu là aussi ( voir même beaucoup )
Cub.
Ludo44
j'eviterais la serie "Angel", pour la simple raison que c'est une pince qui tient l'helice, prefere plutot un systeme vis ecrou.
genre ça: http://www.lxrcmodel.com/details.asp?pr ... d=00690003
pour la TH9x, effectivement, il faut bidouiller pas mal pour avoir le retour telemetrie sur l'ecran radio,
la solution la plus simple est de prendre ça:
http://www.hobbyking.com/hobbyking/stor ... ystem.html,
mais la note monte pas mal du coup.
ou tu fais la modif en suivant les tutos sur le NET, un bon fer a souder panne fine, et HOP.....
othala
Nabil me parlais de flasher le module de la radio j'ai faux ?
F450 - KK2 - D2830
Bixler 1
nabilus
Message non lu par nabilus »
C'est pas le module mais la radio en elle même que tu flash !!
othala
Ok donc finalement je fais quoi avec cette radio moi :x
F450 - KK2 - D2830
Bixler 1
loren3372
bonjour
a mon avis,lorsque l'on débute,la télémétrie n'est pas la plus importante :cote:
Et toujours a mon avis,il faut aller au plus simple.
c'est un coup a s'embrouiller la tête avec la multitude de réglages et c'est sans parler des bidouilles sur la 9x.
Je ne prétends aucunement être un pro dans ce domaine,bien au contraire :perv:
Je pense qu'avant de chercher a construire une machine au top,il est important de maitriser au moins les bases du multicoptere.
Cet avis n'engage que moi.
sur ce je retourne jouer aux Légo
:merci:
othala
loren3372 a écrit :bonjour
:merci:
Je vais totalement dans ton sens ! :super:
F450 - KK2 - D2830
Bixler 1
othala
Question rapide car je suis en train de commander.
Je devais prendre ces moteurs Turnigy http://www.hobbyking.com/hobbyking/stor ... ouse_.html" onclick="window.open(this.href);return false; mais comme c est le store UK et qu'il ne sont pas dispo je pensais prendre ceux ci à la place :
http://witespyquad.gostorego.com/witesp ... 000kv.html" onclick="window.open(this.href);return false;
Est ce les même caractéristique pour des helices de 9 et des ESC de 30A ?
Merci !
F450 - KK2 - D2830
Bixler 1
othala
Une idée quelqu'un ? :$
F450 - KK2 - D2830
Bixler 1
Ludo44
210W pour HK, 150 pour whitespy,il ont l'air pas mal, reste a voir ce que tu compte faire par la suite avec ton quadri...
mais essaie les sunnysky, honetement, tu ne sera pas deçu.
othala
c'est ce que j'ai fais ! pour le moment juste vol a vu , découverte , peut etre une mini caméra embarquée par la suite et je compte un peu m'amuser avec l'APM 2.5 et arducopter !
F450 - KK2 - D2830
Bixler 1
