Aucune idée... à mon avis comme un moteur 28XX (28mmx04mm?)
voici ce qu'ils disent: Looking to make your video platform ultra-smooth? This is the ultimate in smooth high pole count purpose built brushless gimbal motors.
The 2804 motor comes with flush mounting so any DIY to PRO projects are simple and straight forward, it also comes with the standard female connector pre-installed, So wiring is as simple as plugging it in. It’s a perfect match to the Brushless Gimbal Stabilization Board and IMU.
The 2804 is the perfect size for cameras around 100-300 grams (GoPro style).
Spec:
Poles: 12N14P
Resistance: 10.0 omh
Weight: 41.42g
Wire: 0.19mm
Turn: 100T
Bottom holes center to center: 16mm and 19mm
Top holes center to center: 12mm
