Page 1 sur 3
Carte ALEXMOS 3 AXES commande groupée!
Posté : sam. 14 déc. 2013 16:43
par Mizou51
Je suis en relation avec un fournisseur chinois qui vends des alexmos offcielles 3 Axes ! Il est pret à me faire la carte 3 axes à 90$ = 65,5€ ! hors frais de port mais il faut compter 30€ de port pour le paquet en DHL. Soit environ 65+3€ la carte 3 axes!
C'est le prix pour 10 cartes. Pour 20 cartes c'est 85$ l'unité!
Je suis pret à en prendre 2 il me reste à trouver les 8 autres ;-)
Qui est interessé??
Voici le descriptif
SimpleBGC2.0-3 axis
3 Axis Controller Board Of Gimbal with Official AlexMos Firmware
In upcoming version 2.3 of firmware and GUI
"Supports battery monitoring and buzzer"
For the updated firmware to download link as below:
http://www.simplebgc.com/eng/downloads/" onclick="window.open(this.href);return false;
Here is changelog compared to 2.2 version:
v.2.3b2
- Bug fixed: multiple YAW turns caused variable overflow and instability
- Bug fixed: if the system starts in the YAW lock mode, the camera can accidentally rotate to fixed angle.
- If Flight Controller (EXT_FC) is connected and calibrated, the system becomes more stable in the bigger range of inclination angles (even pitched +-80 degrees)
- Battery monitoring and buzzer:
- Voltage drop compensation (PID becomes stable during whole battery lifecycle)
- Low-Voltage alarms and motor cut-off
(This feature will be supported on some newest boards or old ones with the hardware mod: voltage divider 33k/10k connected to pin 19 and active buzzer connected to pin 32. See user manual for details (coming soon)
- RC mapping improved: Any of PWM, Sum-PPM, or Analog modes may be set for any of RC inputs separately.
- it lets to use YAW-encoder or joystick together with RC control or External Flight Controller
- it may be required to re-configure RC inputs after firmware upgrade.
- Serial API extended by the 'C' command (camera control). Example written in C++ for Arduino is provided in doc.
- (GUI) New Full-screen mode available to better fit GUI in small displays
- (GUI) Bug fixed: firmware upgrade fails if working path contains spaces.
Re: Carte ALEXMOS 3 AXES commande groupée!
Posté : sam. 14 déc. 2013 17:27
par willmodelisme
Coucou.
Tu pense qu'une 2axes c'est possible ?
Peut être y a t'il des gens intéressé par des 2axes uniquement ?
Merci pour l'initiative en tout cas.
Posté : sam. 14 déc. 2013 17:34
par Maxxhimum
La douane ?
Posté : sam. 14 déc. 2013 17:47
par nedO
la douane suffit de déclarer 12$ par carte et a payer les taxes ....
le prix est top !
pour info une 2 axe copie alexmos upgradable coute 50e maintenant chez lxrc
Posté : sam. 14 déc. 2013 18:16
par willmodelisme
Les copies sont nulles a chier....
Posté : sam. 14 déc. 2013 19:03
par Mizou51
ca depend....j'ai 3 copies et une vrai...bah pour du gopro et nex les copies en 2 axes sont identiques! je n'ai pas de differences de regulation ! alors pour avoir payé l'officielle 110€ et les copies 32$ fdp inclus! je me sens bien lésé....
On rentre pas dans la polemique de la remuneration de l'auteur du soft...et autre blabla mais faut pas forcément dire ca.
Posté : sam. 14 déc. 2013 19:16
par duxo
Moi, j'en veux bien 2
Posté : sam. 14 déc. 2013 19:20
par willmodelisme
Mizou51 a écrit :ca depend....j'ai 3 copies et une vrai...bah pour du gopro et nex les copies en 2 axes sont identiques! je n'ai pas de differences de regulation ! alors pour avoir payé l'officielle 110€ et les copies 32$ fdp inclus! je me sens bien lésé....
C'est pas trop pénible de mettre le soft alexmos sur une copie ?
C'est surtout ça qui me fait peur en fait.
Posté : sam. 14 déc. 2013 19:32
par Mizou51
Oui ca depend desfois facile desfois pas facile mais bon elles sont livrées en 2.3B4....D'apres le descriptif.
Posté : sam. 14 déc. 2013 20:26
par nedO
willmodelisme a écrit :Les copies sont nulles a chier....
j'en ai une sur une nacelle 2axes gopro et aucune difference avec une alexmos , pas comme lamartinez en alexmos nulled et les problemes de yaw , rien a voir ...;
mais sinon j'adore ton argumentation ...
Posté : sam. 14 déc. 2013 21:15
par willmodelisme
Désolé, je voulais dire que sur certaines copie c'est parfois un casse tête pour injecter le nullalexmos.
(je viens de me relire et mon commentaire est nul tu as raison :rouge: ).
Posté : sam. 14 déc. 2013 21:44
par nedO
y'a copie style martinez qui fonctionne avec version nulled en 2.2B2 par exemple et les carte non verouiller celle ci on les met a jours comme les vrai alexmos ...
Posté : dim. 15 déc. 2013 15:55
par lexa_one
J'en prends une :super:
Posté : lun. 16 déc. 2013 09:29
par seric
bonjour à tous,
j'en prendrai bien trois, qq nacelles à mettre en route, mais peux tu me dire :
1/ on est bien sur du alexmos officiel ? ( upgrade a suivre ok ? )
2/ pas moyen d'avoir des connecteurs micro entre carte et mpu?
3/ la carte semble regrouper les 3 axes (génial ! :) ); a quoi sert la carte en pluche ?
4/ ya les sorties pour buzzer et analyse voltage ?
5/ C quand qu'on les reçoit !!!!!
bon, désolé d'être un peu casse bonbon.......
A +
ERIC
Posté : lun. 16 déc. 2013 10:25
par Mizou51
Pour lupgrade je sais pas pour le moment faudra tester!
Pour la carte c'est bien une normale sur laquelle tu viens mettre le troisième axe comme la carte officielle yen à bien deux si tu regarde bien
Pour le voltage je sais pas mais ça sert à rien....tu regarde la Conso de ta nacelle suivant les power que tu mets sur tes moteurs et après tu mets la batterie la plus petite possible qui va avec cette Conso sachant que le vol ne dur pas plus de 15min....
Posté : lun. 16 déc. 2013 12:28
par Andreas.L
Pour la conso, la sonde sert a adapter le pid en fonction du voltage drop, donc loin d’être inutile.
Posté : lun. 16 déc. 2013 12:50
par Mizou51
ok je connaisais pas cette fonction mais bon mieux vaut pas descendre en dessous de 3.6 3.7 par cellule alors si tu pars a 4.1 4.2 ....en 3S t'as pas grande perte.
Faudra voir si ces cartes en sont équipé.
Posté : lun. 16 déc. 2013 13:45
par seric
ben oui, regarde sur la photo, en rouge sortie 3 axe et en vert c quoi ?
a priori la carte en plus c pour le yaw mais la sortie est sur la carte 1... ok.... apres analyse, effectivement ya pas le buzzer tout ça;
je te parle de ça car certaines de mes nacelles sont autoalimentées et contiennent le pied, et quand l'accus est trop faible, le yaw tourne rapidement, pour attérir c chaud !!
Bon, j'en suis pour deux, mais par contre ya urgence... tu prévois la manip quand ?
Posté : lun. 16 déc. 2013 21:23
par tomeul
Je serais peut être intéressé....
Elle peut gérer des gros moteur pour nacelle DSLR?
Posté : mar. 17 déc. 2013 01:16
par seric
j'ai monté des 5208 24 POLES dessus sans souci..... apres, faut bien équilibrer pour faire travailler au moins les moteurs
Posté : mar. 17 déc. 2013 08:34
par Mizou51
Exact idem! 5208 et poids appareil 1,7kg
Posté : mar. 17 déc. 2013 08:36
par Mizou51
Pour la commande j'attends 20 pers entre ce foro et mk comme ça on aura un meilleur prix et surtout des frais de port diminués!
Posté : mar. 17 déc. 2013 09:34
par seric
cool, la nacelle avec les 5208, une sony 410, recepteur,mikrocopter,accus,bec, pied amovible......1650 Gr !!! gagné !!
Posté : mer. 18 déc. 2013 14:31
par tomeul
Mizou51 a écrit :Exact idem! 5208 et poids appareil 1,7kg
ok dans ce cas j'en suis
Posté : mer. 18 déc. 2013 19:57
par Djeremb
Bonsoir la compagnie, je serais partant pour une carte moi aussi!
Sent from my iPad using Tapatalk
