Nouvelle Carte 3-axes Alexmos pour GROSSES NACELLES
Posté : mar. 29 oct. 2013 11:00
W-BGC for large Gimbals
$ 330.00
A high voltage and high current 3-axis brushless gimbal controller which based on AlexMos L6234 BGC and the design of 3rd-axis expansion board.
It can be widely applied to various brushless three-axis stabilized camera system and perfect match with AlexMos authorized firmware.
W-BGC use high-power mosfet driver chips instead of L6234 which used on AlexMos classic
hardware.
With rich experience in power supply design, Elite Power engineers solve the
momentary shorting issue of the traditional mosfet BGC controller So it has real larger current
capability that can be easy to drive large motor such as 8017,10617 motor or above.
_________________________________________________________________________________________
Specifications
* Product name: W-BGC
* Product Model: 6S-3
* Product version: 1.0
* System type: 3-axis
* Dimensions: 60x45mm (main board)
* Fixing holes: 55mm x 35.5mm
* Input Voltage: 12-26VDC
* Battery Lipo: 3S . 6S
* Max continue current: 70A(@74F)
* Burst current: 280A(300us)
* ConnectionF USB Cable, Bluetooth
* PC (Desktop, Laptop): SimpleBGC GUI
* Remote Controller: PWM of Analog or PPM-Sum Input
* On board Control Modes: Follow mode or Lock mode
Features
* Multi-voltage power supply
* High voltage input
* High current
* 3 axis in 1 board
* Three-axial independent
* over-current protection
* Highly integrated&ultra-small size
* AlexMos authorized firmware
* Hardware lifetime warranty
Packing info
* Main board X1
* Wiring board X1
* Power capacitors board X1
* IMU board X1
* 6pin ISP cable X1
* 12pin FFC cable X1
* 4pin shielded cable X1
* Mounting pillar X8
$ 330.00
hardware.
Specifications
Features
* High current
* 3 axis in 1 board
Packing info
* Main board X1
* Wiring board X1
* IMU board X1
* 6pin ISP cable X1
